frumpy
can you post a couple of pics with the body off?I fitted my body today but had to heat up and bend the rear posts backward to get the holes to get alot closer to being lined up.The side posts are basically unusable as you can see in the picsI have the 6202/01 body which has the wider hole pattern in the front but that shouldn't matter for the side posts
It's almost like the front end is bent up a bit forcing the body back on the two front posts.....
