belt drive square gear??
blak__jak
does anyone know if since I have the belt drive setup with 7075 gear plate is it possible than to use this in conjunction with a square drive gear set. why I ask is even though the belt drive works great in some cases like hill climbs i'd like to be able to change to a lower gear than the belt drive without having to change the gear plate to put the four pin gears back on. not ever having the square drive setup i'm not sure how it works.
For your kit, yes. You just need the three squares and the four gears. You just pull the pulleys off and slide on the squares and gears onto the shafts.
Here ya go.
thanks man. your tops. still haven't seen jimmie? kinda getting the run-a-round from ups.
