Best Losi 5ive Air filter?
Tgn has the dt1 duel stage outer air fliter with Neoprene on the edges so you can grease ot up. And they also have the dt1 inner filter as well. I run them with an outerware prefliter. Never had any problems. And they fit the stock air fliter houseing
I've been running a stock filter for well over 2 years. I see no need for upgrading the filter in my opinion. If you are concerned that it pops off sometimes...that's an easy fix. You put two small plastic ties where the two plastic parts of the frame meet before you put on the outer filter (gray filter) and you'll be fine. You could replace the stock portion of the stock air filter mount with this part...it's more sturdy and mount warp or melt with the heat.
http://www.davesmotors.com/Products/Shread-Industries_3/
