Best wheel raplacement for my xt
Erik J.
I tried to put new foam in the wheels of my xt using pool noodles but the tyre was stuck on the rim so i ripped a hole in the tire getting them of the rim.i had them in hot water for 20 min.
What are nice replacement tires and rims for the xt because i don't want to buy new stock tires so i don't't waste another tire.
Proline rears all the way around with the Proline Trenchers makes a great combo for the trucks. You will need either 7075 RCs or Rampage Hopups adapters. Both are great!
What kind of compound is best?soft,medium or hard.
I found FG tyres 190*115 with wheel square rims that fit the xt wheel square.
I only need to make a 2mm spacer because the square on the xt is 12mm and the rims have 14mm square hole in them.
The square drive for the Xseries is a 17mm square. The axle bolt won't reach through the wheels either so you would have to mod the axles.
Erik J. said:
What kind of compound is best?soft,medium or hard.I found FG tyres 190*115 with wheel square rims that fit the xt wheel square.
Depends on surface conditions. If you're a basher, go with a medium to hard compound tire.
