ChuenouXiao
Anyone know the best known hop up for the XB break? Any known trusted site?
Here is my problem. Once I hit top speed of 36 MPH so far, and if I break instantly my tire doesn't lock completely and screech. Instead it slows done about 10 XB length and then stop. Now I expect tires screeching to a stop. Now please note that if the car is in idle it doesn't budge when you break. Do I have to reset my set screws for my break? I don't want to ware off my break too bad because of me setting the break too high. What is the proper procedure to setting the break properly?rcgasser said:What is it that you are trying to hop up on the breaks? The breaks works great and grab good.
I have the HS-5645 MG Hitech for my throttle. I don't expect the car to stop completely but I do expect it to lock my tires to where the tires would screech. I mostly run my XB on pavement because its not setup for off road yet. So you recommend me setting my brake screws?Deluge said:What throttle/brake servo are you running? Also, it depends what surface you're running on. If it's dirt, it'll break traction if you lock up. But if it's on road, it'll be harder to lock up because of higher traction. Consider the weight of the vehicle, as well. 20+ lbs at 36 mph, it's just not going to stop on a dime.
Oh I see, but how long does it roll when going around 36mph per hour?rcgasser said:When I brake hard on mine it will still roll a little then stop.
Is that even possible?cordy said:Put front disk brakes on it will stop on a dime.
Not far!!!!!!!!!chuefengxiong said:Oh I see, but how long does it roll when going around 36mph per hour?
How many XB length (LOL)?rcgasser said:Not far!!!!!!!!!
