Big bore engine kits
Stuffed crankshaft reduces crankcase volume, resulting in improved throttle response and engine power.
The built in Stuffed 2mm stroker crank alone will add 15% more power to you motor.This stroker will mostly add bottom end. Big difference for $12.00. :D
Thats what I was thinking.
How complicated is this to put in? Do you need anything other than basic hand tools?
That doesn't look too bad. What he installed that tutorial appears the same amount of parts as is in that kit I was looking at with the stuffed crank.
How do you pull the flywheel and stop the piston with out those specific tools?
