kmiller
- Saint Clair Shores, Mi
Well I'm new to 1/5 scale cars and bought a used Fg Marder 4wd, ran strong for the 3 short times i used it. I was running the other day and I thought I ran to low on fuel, car did not want to stay running... I filled with gas and supper hard to start and once started it would run wide open for a few seconds and stall. I pulled the engine to take a better look and found the head cracked from the head bolt under the exhaust port and the small exhaust port brace. It is a kingmotor and I was told it was a zenoah (my fault)... It has a DDM Dominator Chrome Pipe (unless thats a knock off as well? The way the pipe mounts is solid, is that why the head cracked? If it was a zenoah would it have cracked as well?? What engine should i replace it with?
See my car here...
https://www.largescaleforums.com/showthread.php?t=16875
See my car here...
