madr1rider
Thinking of getting them for my car, as the plastic one is worn. Are these any good?
BE VERY CAREFUL to check the SHAPE of your shafts.
If I am not mistaken, these are the gears that have been manufactured with the 'flats' opposite each other, and not at 90 degrees.
This is the only reason I was unable to purchase them, as I have the tuning shaft, with the flats at 90 degrees.
yes are good gears, i get them direct from the guy who makes them(bullet tooth troy msuk) or herby on ebay.he stocks freeprawn,so go direct to troy.
i use them on all my buggys and he does ratios that fg don't.i got some
28/36 coming!!!!! he also does 44/46 48 50 for diffs.
what size you after, i have loads
