rsgonzales
- Reaction score
- 0
I ordered a mt blue aluminum gear plate for my xb with some good ss bearings
problem is the brake rod.the pin that holds the brake pad one is to long do i need to cut it .and I also orderd a gear kit 3 25 tooth so im useing 31-29 swapped them a n b then 3 25 gears will this increase my top end speed .
I would think im going to have to cut one of those brake rods..and will the 3 25 gears work also i built the diffs (2 hours to clean them) lockte all set screws.I ordered good bearings 19 10 5 .stainless steel beaings .do you think a good quality bearing will hold up .I see rc dad has hubs the 6 mm shaft i have the 10 mm shaft I guess it will work if i get the bearings from somewere else.well we shall see.can some one please tell me if i need to cut that one rod?brake rod
