Body repair tip
Rampage mt
Nova Scotia canada
Figured I'd share somthing i do when I crack or break a body.i do construction work and for finish work I use stuff called mitre pro all it is is simply a strong glue and a spray accerant It's expensive but I'm sure any similar stuff would work.all I do is hold the crack or even broken off part in place run a bead of glue along the seam then spray it with the accelerater it turns white and ur good.no lie it holds I've NEVER broken a glued spot it will break somewhere else before the glued spot,I'm sure a super hard hit would mind u but just a good idea for anyone needing to fix a crack!
Nice tip.
Sorry it's takin so long,I actually decided to make a video showing the process but its taking forever to upload via my YouTube acc.file was too big for the forum I think.ill try to get it on here over the weekend
ok heres the vid,youll have to excuse my Canadian hillbilly accent haha and I know the video quality is pretty all over the place but it was hard to do while smoking and trying to tape haha but hope this helps!!
[ame]
[/ame]
