Boot Modifications
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Don’t throw out those used boots.
There are a couple things to do with them.
First you can use the end of the boot on your carburetor linkage. Cut between the 4th and 5th rib and install it to help reduce the crap getting sucked in the side shaft.
Second you can use that same boot cap with the two ribs left to cap off the top spark plug hole.
considering getting them on without splitting them is a PITA, prolly not much.
thats a good idea
hey where do you guys get thoes boots will they work on my fg marder ball drives???
and also that is a good idea to use the boots for :)
