Brake Adjustment
local150
Junior Member
The brakes worked great and then just quit working. The servo was operating properly. Anyone have a procedure for adjusting?
The only adjustment would be the linkage or servo travel.
A lot of the time the brakes stop working as a result of one the set screws backing out of the brake hub and getting in the way of the shoes. It keeps them from clamping properly.
theres also 2 grub screws trucked away between the center diff and bearing holder(hard to get to and hard to see but if you take off electric box you can just about get to them), you can whind them in to ajust where the pads sit and the amount of brake travel
