Trip
Hey guys I need some help diagnosing the brakes on Kermit.
My brakes are only working about 40% of the time. I won't come to you guys with something simple like servo throw or dead battery issues. The problem is when I hit the brakes while the car sits on the stand they work 100% When I push the car around on the ground, they are 100% ...But when the engine is running, they either work perfectly or not at all!
The brake discs are perfect, the brake calipers appear to be in working order, the rod that delivers the servo's command is working properly, the servo obviously works, I wouldn't come to you guys with something that simple. I do notice the vertical rod that rides in the brass bushing in the bottom of the chassis does rise up from time to time. Could this be the culprit?
Here are some pics.
The linkage is slightly bent to clear the mounting screws for the throttle servo, I am the one that did this and the brakes were failing before the addition of this servo and linkage modification. In fact, the brakes have been like this since I took it out of the box and since I don't believe in sending poop back for warranty, this problem is on me.
Before it's asked, yes the servo travels to it's extent every time I hit the brakes, the servo travel is the same whether the brakes are working properly or not. The Tygon fuel line is not sliding through the eyelet on the brake lever, it gets squished up even when the brakes are malfunctioning..
When the brakes fail, I can pick up the car and rev the throttle and then the brakes will work again, usually.
Like I said, this is not a simple "Gee my brakes don't work" I wouldn't bother you guys with that rubbish.. I haven't had the braking system completely disassembled yet, so I can't say for sure what is malfunctioning.
Any educated guesses?
Thanks for your time guys,
Trip..
Here are some pics.
Trip..
