Brake help
island
Guam USA
Help my brake servo moves so slow when hitting brakes but on gas very quick? I have change servos twice and still the same could it be my futaba
3pm settings? Please help
Its on the hand held. Sometimes they can be confusing to learn. Its a adjustment is all
there should be a setting on your controller that allows you to change the sensitivity/speed of the servos, youd have to look in the instruction manual as i cant rember what the setting is called without getting mine out :p
could also be your EPA (End Point adjustment)for your braking, when you apply your brake does it move same distance as applying throttle? just to try and narrow things down for you
and as deluge said could be your abs, when you apply your brake does the servo slightly twitch when it reachs the epa?
just looked a little about your controller and i see it does have "servo speed" setting on it, id start there
