brand new 23cc
kingmotorguy
so i just got this thing braking it in started acting like the rear end gears were snapping so i pulled it out an there fine spur gear is fine clutch is fine what else could it be? anyone
sounds like your diff or the drive gears have blown, if you take the gearbox out and split the black plastic casings, you will see 3 drive gears if they are still intact, then its yea diff, how many tanks of fuel has the buggy had?
if the rear wheels are hard to turn that sounds like drive gears, but to be honest i,d contact the shop or seller you got it off and explain whats happend after two tanks of fuel.
i will thanks cause i just put it all back together greased the hole rear end an nothing gears are fine in the rear is there maybe a out put shaft or something im missing
the rear wheels spin fine i don't get it it almost like the clutch barely ingages put its a brand new car full throttle moves like 5 inches :mad:
is that hard to fix ?
no its quite an easy fix, take the clutch bell off again un bolt the clutch shoes you will need to lock the motor up to stop it turning while undoing the bolts, when the clutch shoes come off you will see an alloy mount that bolts to the crank, tighten it down with a hex.or just send the whole buggy back,
so i pulled out the diff again today an pulled apart the spider gears an looked at the gears that actually go to the axle carrier an they are completly gone must be from cornering to hard is there a way to fix this it has the stock rear end thank if anyone knows
yea baja diffs and drive gears don,t like flat out drifts ,here,s a pic of my gearbox from lastweek
first time ive heard that! everyone i know with one has them more sideways and theyve never had that prob, must have been something outa whack from factory.
