Brand new mt pro v3 won't turn over
Meares
Junior Member
Just got my my pro in and can't get it to start. Using 91 octane fuel with 25:1. Tried starting with choke on and off. Nothing. Cleared chamber each time. Set carb to factory on high and low needle. Checked plug for spark. All good there. Primer bulb is full of fuel. Doesn't even pop or make a sound like it's trying to start but I am pretty sure I'm getting fuel and spark. Any thoughts. This is my first fuelie but have ran lots of nitro from cars to helis. Thanks.
U need to keep adjusting yur LSN till you hear a combustion. When you start hearing it combust then your on the right track. Factory setting isnt always the best to get it started for the first time. Only try twice with choke on. The try another two times with choke off. Anymore than that at a time will flood the engine amd foul the plug. Remeber small turns goes a long way on the LSN
Low speed needle is only for idle and to about 1/2 throttle. Set it to 1.25 turns from bottom. Set it carefully. Things change radically at 1/16 increments!
Prime the bulb full. Pull the starter through twice SLOWLY. Don't try to start it. Then yank the handle about two times and it will start. Every time. All the time.
If you plug is bad or coil is misadjusted expect more pulls. But this works for me.
