Brass fitting
ChuenouXiao
California
The install was a pain in the butt and took so much of my time because I was trying to install it once and properly. I slip fuel line on the brass for a tight fit on both and cut the brass going back to the tank. Looks good now :D The other brass is slightly taller because I did not cut that brass and the fuel line that was on that long brass goes all the way to the filter :D which should be good too :D It took so long trying to slip the fuel line to the long brass that I did not cut.... :D What do you guys think?
Looks good. I cut all my fittings but anyways you did good. A lot cleaner then lines just sticking out of your tank
Looks great Chue.
The fuel line is a PITA to slide up the brass fitting. I used a bit of 2 stroke oil. It helped some.
RCDAD said:
Looks great Chue. The fuel line is a PITA to slide up the brass fitting. I used a bit of 2 stroke oil. It helped some.
Yep... lubed it and its still is hard RCdad :D ... because on the long brass.... I pushed the whole fuel line all the way to the top of the brass, It was worth it though :D
