ChuenouXiao
I purchased this... should I cut one of them short because its simply going to drip fuel back to tank? Or should I leave it? Anything I should know? Any possible issue? I have the three hole snappy gromet... just a FYI
How about a link. I also got the brass fittings and like you didn't like the idea of tubing but had no choice so I have it on mine but like yours betterxscrick said:i had bought the full force rc kit for the baja on special recently from ddm,, and finding out it didnt fit right,, didnt like the idea of sliding tube over it,,, to me felt would be sloppy fit, so went and bought a sullivan gasoline/diesel fuel tank conversion kit (No. # 484 ) ,, paid $5.49 comes with almost everything you need. bought dubros 1/8 tubing bender for bit over $11 bucks but now i have a new tool.. Also bought the solder on barb fitting for the tubing,, couple bucks for those.. and once u get set up, should work forever.. i haven't finished it totally yet,,, but i will include u a pic to show u what it looks like .. and once u tighten it down, nothing is moving and is perfectly sealed,,,,comes with 3 holes, but only two holes on rubber stopper is completed,, so you will have option for a 3rd line if u want
+1You need to cut the one you are using to vent the tank for sure and you will also need to put small pieces of fuel line around the barbs where they sit in the grommet the brass fittings are too loose they will leak if you do not, TRUST ME I no!
I use a little 2 stroke oil as lubricant and cut the line at an angle.They work good. Just a PITA to fit into the Redcat tanks. LOL
Now I always just use a whole new tank with grommet installed and go from there.![]()
I tried what Phil suggested but I used my Redcat grommet used fuel line on on the brass fittings and stuck it in the grommet with 2 cycle oil and cut lines with an angle
I pull grommet out of fuel tank and used 2 cycle oil on grommet to put back in the tank but I will tell you it is a royal pain to get it back in the tank but its worth it and it will not leak make sure to reinstall fuel filter the full force fittings works great for the DDM Dominator pipe to keep fuels away from the pipe your the man Phil !!!
