Break in fuel mix ?
It is 5.12 ounces of oil to 1 gallon of gas. As long as you have 5 ounces of oil in the gallon of gas you will be good.
fuel mix
on ocassion, i just mix up 1 quart of fuel. I use epoxy mixing cups from the lhs. these cups are cheap to buy- they are 1 fluid ounce cups. they also show drams, cc, ml, tbs. I should put 1 of these in the kitchen cause its better than those little measuring spoons that grow legs everytime i need to use them!!
I got one of those ratio cups up to Wat line I fill up and can I use any brand of 2 cycle oil because I have to ored online now one sein to have castrol or amsoil or good brand
You got a Ratio Rite cup? Gallons are at the top of the cup, if you're mixing a gallon go to 1.0 and the ratios will be listed right below it. Closest you're going to get to 25:1 is 24:1, which is fine. Just fill it up to that 24:1 line. I've used Lucas 2 stroke oil and it's good stuff. If you have an AutoZone near by, they carry it.
Thas the one I fine in advance auto Lucas 50:1 semi synthetic something like that white bottle blue sticker rite is that one if the same one u use let me now I stick with that one thanks deluge
Hey bi the way how can I post pic in my user name ?
