Break part missing
AceM
I looked in the manual and there is supposed to be another pin on the other side, however i cant find where the pin is held
On the left side it is held in by the screw mount but on the right side there is nothing to hold it
The 2nd photo is the bottom of the brakes, is there something that is supposed to hold them, or is it only held in place by the 2 pins on the top?
https://i.imgur.com/S3Pza8n.jpg
There should be 2 pins made into the outside pad closest to spur gear. Looks like you broke one off. And no, nothing holds the bottom, only the top pins
I realize i spelled brake wrong lol
So if i order another pin, how does it get held in, i couldnt find anything in the manual or exploded views that support the pin from coming out
Make a pin from the appropriate sized drill shank and glue it in with red Loctite.
I can do that, but is this a design flaw or something, it seems weird that the pin is not secured
