breaking shocks
i bought the redcat hop up shocks but there no stronger, i pit bash it hard, other than that no problems, just orderd 28.5 cc cyl. what do you forsee happining with that ?
Use the search function in the upper toolbar and search for "6mm shafts" and you will get a few options, that's what I did and currently am using the HPI 5B SS HD 6mm's and they are great......and with the 28.5, get a pipe and you'll be able to break even more stuff :D
the stiffer clutch spring is available at http://www.rampagehopups.com/product.sc?categoryId=5&productId=334
i am also running the 6mm hpi shock shafts. theres lots of info if you use the search key. many of us have dome slighly diffrent set-ups, but they all revolve around the hpi shafts.. the install is not perfect, but is easy and cheap as well as extremly tough. phatdad says he is making another batch, but we have only been waiting for about 3+ months. when it comes back out they should be about $135.00 for the hole set. the hpi set-up is about $64.00
