phreerider
- Reaction score
- 4
what has been described sounds too rich on hi needle, squeeze the hi speed down find the peak again
if its the stock carb (?) that maybe all you're gonna get and won't matter what you do.
could be a fuel flow problem, filter, screen... esp. after leaning it out a bit.
heres it from DDM....
If your engine stutters at full throttle and cannot reach full RPMs:
The high jet is too far open. Close the jet by turning it clockwise slightly, and then ride-test. If no improvement, repeat until desired results are achieved. Once you have found a workable setting, open the jet approx 1/16 of a turn to ensure sufficient fuel/air mix.
