Yesterday I was finally able to take my DBXL out for a decent run. I'd previously run a couple tanks through it breaking in the engine. Yesterday I noticed the Rx would brown out from time to time. Not necessarily too far away either. I'm using the stock DX2E and SR310 with a 2000 mAh 2S 25c LiPo. I made an adapter out of servo wire as the LiPo has a Traxxas end on it. The wire in the adapter I made is lighter than any of the Rx or servo wiring on the buggy. Could this light servo wire be causing a voltage drop that would brown out the Rx? Each time the Rx would reconnect after about 2 seconds but it's a bit unnerving. Any ideas on what I should or check?
