Building a Zen G290 help!
shua
Roanoke, VA
So I'm building a G 290 with an ESP 30.5 head and +2 stuffed crank.
I mounted the CY clutch housing and I noticed that the CY clutch housing pushes against the outer bearing. In fact, It pushes the bearing in one millimeter into the crankcase.
Is this going to be OK or do I need to press the bearing back out to its original location and just use the Zen clutch housing?
