rcpwr4me
finally i start putting together my parts and ideas, and turn on the lathe and mill and got some good results,this is the engine for the 1/5 scale buggy or rail project that i been so long delaying.
the engine is a hybrid,is basicly a g62 with a redmax(komatsu zenoah) chainsaw crank,the flywheel is from a g230pum also the coil(red coil).the carb is a sthil chainsaw HD5 walbro 16mm bore,made my own high compresion billet head with decomp valve and made my own copper gasket out of .018 copper sheet.planing to install a nology discharge coil and use also the nology hot wire.the engine is not done yet,i just like to share to have some r/c gearheads comenting.
i read in some of the threads that the g62 is heavy...that power to weight ratio...non of those engines are ported...ect,with this tread i will try to get to those issues and see if i can make this engine lighter,high rever,and high p/w ratio...will see now to download some pics.
