Yes I used the adapter from DDM so you can use the smaller pull start so you don’t have to chop the side frameHi Deathrawt
Nice write up.
When you installed your 46cc did you also use a smaller pull starter or did you stay with the one that came on the engine. Also, with the 46cc did you use the original pipe as such able to keep your driver in place?
Sounds like you found your sweet spot.
Enjoy.
I used the stock pipe with the engine but you still have to remove the driver figure unfortunately
Yeah it didn’t do much that’s for surenothing you did wouldn't have added substantial if any power to the engine, it would have needed ported to see any real gains.
It ran smoother with the low side now able to be adjusted and having a proper choke was nice
Someone needs to design a proper top end for it and then it could be a decent engine
