buy Losi 5ive-advice
smartech uno
Israel
Hello
I would like to replace my 1/6 buggy car (after several problem ) -smartech uno
I have a lot of problem to start the engine (I have the car 2 year) ,now I replace the carburetor without chock and the same.. Maybe it’s because I not mechanic?\do not have the knowledge? (I read in forums how to start and etc.. –its not help)
so i think maybe if i buy more Reliable,strong car and the parts are more good
its help
my question are : can i upgrade to this car type or its to much Advanced for me??[FONT=&quot] [/FONT]
*in my country i do not have any vendor\support **
[FONT=&quot]Thanks[/FONT]
I presume you have replaced the carb with an 813 Walbro?
No choke and accelerator pump.
There's a simple starting procedure:
1. Prime using the bulb in the carb as normal.
2. Tx/Rx on, and 'pump' the accelerator 3-5 times before starting.
(You should smell petrol at the exhaust now.)
3. Start the engine and run as you would normally - should start in 2-5 pulls maximum.
Al i think part of the problem with this guys engine is that he has changed
from mineral oil to full synthetic without first:2guns: cleaning out his engine
causing a gummed up engine,maybe even a stuck piston ring :D
k....
k....
Hi
Thanks for the advice,Help
what you say Regarding Possibility to upgrade the car Below to what I wrote above?
Thanks
