C-Hub Bearing conversion
Andi
Wakefield, UK
I know I'm prolly treading old ground but I know someone converted the C-Hub fixing to the Hub to Bearings and I'd like to know what size bearings were used and what hex screw / nut was used?
I've lost yet another today and I'm sick of it so I'm gonna convert it to bearings to try and avoid this again.
Thanks in advance
Andi
Hi Andi this is what you will need to mod the C-hubs only the bearing will be needed , do you have the alloy c-hubs or plastic ones
http://www.rc-car-online-shop.de/cg...m=va_0004&file=&gesamt_zeilen=0Tsuche--y18002
also you will be needing a 13mm drill bit to open up the hole to allow the bearing to fit im not to sure how handy you are but its a fiddly job mucker
ive done this to 6 cars now and it seam to be holding up very well.
