Can the gears be upgraded? I just want to know so I can see my options incase I want to ever upgrade the ESC & Motor.RazorHobbies said:Yes we have installed one for a customer before so yes it will work. However after installing it on a customers car he did encounter issues with gears stripping after buying larger voltage lipos. Reason being is it puts more stress on the gears at the higher torque.
Ok, I'll have to check into seeing what manufacturer may have what I'm looking for. I thank you for you info, and feel free to share whatever you could if you come across something concerning this.RazorHobbies said:Yes gears and the spider gears in the differentials can be upgraded. You just have to cross match the spider gears with another manufacturer part to get the hardened gears.
thanks I appreciate that much.RazorHobbies said:I just talked to him yesterday and the gear set he used was an old gear set of robinson racing that they used to produce for the HPI MT.I will look around for you to see what I can pull up in hardened steel gears that will cross reference.
I wouldn't know, because I'm new to the Redcats Caldera 10E, But since on the subject how do you like yours and what do you think of the speed and power using Lipo batteries?Ryneito said:How much difference in top end between the 13t and 15t spur gear? I just stripped both spur and pinion so im in the market for a new set..
20-25mphs or 30-35mphs on the 2s LipoRyneito said:Power on lipos is good. Im running 2 cell 3600 mah and it moves. Not as quick as my hurricane xte on dual 2s. Good basher truck tho takes a beating.
Just to answer your question about the difference. It is not much your looking at small differences. Obviously if you go with the 15t spur you will have a slight increase in top speed. But its not going to be a very big improvement just a small improvement.Ryneito said:How much difference in top end between the 13t and 15t spur gear? I just stripped both spur and pinion so im in the market for a new set..
