Camber, caster and toe on Rampage MT?
waqr
Sweden
Hi!
Today I started to look at the wheel settings on the car and I noticed that I had several degrees camber out on the front wheel`s (they are leaning outwards).
What wheel setting should I have on the MT front and rear when it comes to camber, caster and toe?
if your running the stock monster wheels, i wouldnt worry to much just make sure everything is stright (neutral camber & toe) it what ever change you make wont make to much diffrence because of the tread and size.
Im using baja tarmac buster wheels and run slightly negative camber all round(top of wheel pointing into the car? :p ), and slightly toed in on the front (this is how i set up for road use)
