if you find you have no spark. try again with new plug. if still nothing. make sure the red kill switch is not stuck in. these are the most likely things on a new truck. if you find you do have spark than your problem is probably carb related. as rcdad said flooded because of lack of vent or out of adjustment or possibly loose. if you find your plug is wet try setting needles on carb to factory default. 1 1/2 turns out. while you have the plug out you can pull the ripcord a few times to clear out any excess fuel, turning the truck upside down sometimes helps with this, let it dry out for a little while than reinstall plug loosen gas cap to eliminate any venting problem make sure you have fuel in primer bulb and try to start it again. if this doesn't work for you look around on here there's a complete engine troubleshooting list somewhere I just can't seem to find the link at the moment. hope this helps. good luck.
