Can i use mcd steel gears?
GTS 666
Central West NSW
Hope that someone here has some info on using Mcd steel gears as mine have seen better days and is is easier to get the mcd gears. I wanted to know if they fit is the mcd gear plate the same as Redcat. Thanks in advance for help. :)
I don't see why they wouldn't work. I've been using MCD plastic gears for a while now without any issues, and I doubt the steel gears are much different.
My C and D metal gears are shot one is missing a tooth and i have replaced it with a plastic gear but i don't know how long it will last. Are the Mcd for C/D still 25 tooth. And can you run plastic Mcd gears on A and B thanks for help.
Yes. I run MCD plastic gears on A/B. For C/D, I'm running these. MCD does make a 25 tooth steel gear, but as far as I know, they're not sold individually and the sets are expensive.
mcd gears
i run the 24/25 on all thee of my red cats now for the past year on my c&d gears. u can allso run the xb xt gears all so . fit is much better than the dtandard steal gear sets i have found.
Thanks for help. Will Fs racing steel gears work 33/30/24/25 I'm just trying to keep my options open until demon releases the two speed.
That was my first thought too but they describe them to fit Redcat and MCD so I was just after some info to see if they will work.
