Hey guys I just purchased a used MT from a guy off of craigslist for 400.00.
It had a bad steering servo, but he gave me an extra one he had that was bad as well.
I pulled the servo out and tore it apart, one gear was chunked pretty bad. I made one good servo out of the two and got my truck to turn without issues.
I noticed last night that the carb linkage is really sloppy where the rod goes into the hole on the arm for the carb.
Is there any way to take this slop out? Do they make a small enough clevis that I can use with a bolt running through?
I also noticed that when you give it full throttle, the butter fly will open about 90% of the way, then after the carb linkage rod get done deflecting it will open the remaining 10%.
Any ideas or pointers to getting a better linkage, or a better actuation?
