Carb Question
Look where the butterfly shaft is exiting the carb and not on the side where the shaft wide open stop is. You will see it say WT or WA and than a set of numbers. Old days you would read the numbers left to right. Now they are top to bottom. Carb is probably upside down if mounted on motor. Should be like: .....WT
....................................................................... .................................. ...........644
