I cut the screws down before since I did that exact thing a couple years ago!DemonRC said:There's a problem with the ZRC intake that can easily be fixed. If the main bolts that go through the airfilter housing and carb are too long they will protrude through the back of the intake manifold and push the rearmost gasket off the manifold. This will cause an airleak and can possibly let fuel to flow out of the fuel passage. Check the rearmost gasket and make sure it's seated nicely and not bent outward.
