Carbs...whats the difference???
voo2doo
In Memoriam
PLUS member
Flintshire,North Wales
Hiya dudes
Can anyone tell me what the difference is in the Walbro carbs? Theres a 668,605A,813(i know theres an accelerator pump in it) and so on.All look like they have the same size venturi's and physical apperence but what is good for what engine and why?
Cheers
J.
Hey voodoo...688 has a choke...813 has the accl pump no choke larger internal jetting..
771 same as the 813..but no accl.pump no choke..has larger jetting..for fuel flow..
Not sure on the 605..thought small internal jetting for use on the 23cc on engine.....
I am sure other's will chime in here as well...Slawhammer
the 668 is a great carb the 813 is good not so much for off road imo
the carbs its like this
603
668
771 (no choke)
813 (no choke)
these are the most common in offroad but theres more out there
normaly the higher the number the more fuel it gives your motor, but with some boat carbs its back to front
for general bashing you cant go past the 668 its relible easy to tune, holds tune well and last great.
the 813 to me can be a problem child in sand and dirt and needs to be moded befor use, for general bashing and off road stuff i recomend the 668 and i use it on my ported fg mt motors.
