castle xl2 with leopard 5692 1090kv motor
bigfol
Avoca Beach,NSW, Australia
picture.php
This is my old set up, neu 1527 install pic's coming soon...... :)
big fol thank you for the pictures
about the heat shrinks from where you got the red one
I keep seeing this quote about Longer BL is Better? I'm assuming this 1527 is about as long as it's going to get in this kit? What's your review of this set-up?
Mike
Longer is definitely better. Fatter rotors cannot handle being spun to fast without shattering . Something to do with to much weight . This will definitely be my next motor .
I have a few parts to buy before I get that cannon but from what I can gather that motor was made for the xbe . Efficiency and scalability . I have heard of the boat guys spinning them up to 70-80k rpm .
Its a 1500kv 1.5d motor 8mm shaft, the down side with this motor is the D windings they run a lot hotter compaired to the Y wound versions, thats why water cooling is a good thing with this motor, I had a few runs, geared 14/45 and it over heated, the glue holding the rotor shaft to the magnets let go, currently running a turnigy 5692 1000kv motor,I adjusted the motor torque settings through the castle esc, I hate to admit it but,its putting the Neu 1527 to shame..... :eek:
bigfol said:
currently running a turnigy 5692 1000kv motor,I adjusted the motor torque settings through the castle esc, I hate to admit it but, its putting the Neu 1527 to shame..... :eek:
What gearing are you running with the 1000kv?
