charleshodge
- Reaction score
- 0
Wiil castle ice 2 160 ESC work just as good on 12s with 500kv motor as mamba xl2 on 780kvmotor? Thinking lower kkV and higher volts should lower amp draw.mechanical brakes should make using cc 160 not a problem.both ESC have same amp rating,just able to go to 12s and amps should be lower. Thinking that could help the situation that is the mamba xl2 not really being sufficient for a 40lb 4×4. Thinking 160 on 50v might work better.also,is there any hydraulic brakes out for a 5t front only or front and back?
