Changes......
prostock
New York
So I started installing the upgrades and some of the stock hardware was a pain in the "A" to remove, the factory used red lock-t on some of the screws. Also some of the heads striped so I decided to upgrade the hardware to stainless!
ACE is the best for hardware they have everything; well almost everything I am waiting on the shock and hinge pin(no more c-clips) hardware to come in.
BRC
its lookin real good. im hoping mine (mt) will get here soon. wondering if its going to have the same chrome rims that you got.. it was suposed to be with the shipment as yours(pro5th) but i still haven't gottin it.. i see you put some philips screws in their? you like them better? did you get a clear shell. if so, post some painted pics. i see you pulled the mill. whats your plans with that?
Thanks kryp,
The reason for the phil heads is ACE had more of the sizes I need and not in hex. And dealing with one #2 phil driver verses 4 different hex drivers is a little easier come maintenance and quick field fix time.
After I run the motor I will decide on what upgrade to do to it. Maybe a head kit or a whole new motor.
The body came clear and I sprayed it with some left over paint I had laying around came out like crap. I will be pitting the Asgard body on it next month and that will receive a really nice paint job.
I also centered all the dogbones to reduce play and lubed the bushings in the bellcrank. Didn't have time to look for bearing for it yet. Added HPI ax-boots also.
BRC
Actually to shim the dogbones I bought some nice rubber spacers but they didn't feel right, the rubber was to stiff when compressing the suspension (like binding) so I used some #2 shock pistons (team assoc).
They fit nicely, and the suspension compression is good. I will take a pic!
BRC
mooman007uk said:
Just to chime in out of turn, I used 1/2 of a decidamp ear plug in each cup and they work real good.
That an idea, I might try that to see how it feels!
It might not come with the chrome wheels. I race with pete and frankie from pro 5th and they stop making the chrome wheels because of how easy the chrome peels off. You would have to buy them from LargeScale Rc seperate.
Yep they sure do thats why mine are white now.
Pics, the x-can is mounted!BRC
/monthly_2009_01/583c60549264d_Xcan1.JPG.8bfb3ba15103ff6fe224cb6f1aa36f24.JPG
/monthly_2009_01/583c605493c53_Xcan2.JPG.f736795e029e6fdd4ee6e17b4e883998.JPG
/monthly_2009_01/583c60549561b_Xcan3.JPG.e42e1b730139474f83ed5fd1f649f457.JPG
/monthly_2009_01/583c605496ca8_BodyShot.JPG.bef646b405518ca7dc8a1da2d444cdcd.JPG
More pic's!BRC
/monthly_2009_01/583c6054986e5_BlueTubing.JPG.ba7784337c7a5c4148fc0d8e74fdb1e1.JPG
/monthly_2009_01/583c605499e4e_RadioBox.JPG.9eb71945528ea91356dfd7764a1739fe.JPG
/monthly_2009_01/Chassis.jpg.73be215d67956b3e83cdd643da5053b0.jpg
Thanks Bryan,
As soon as the weather clears I will continue with break-in and a full performance review!
Also more changes to come!!!
BRC :D
