Changing a Dunerunner 4WD into a 2WD
racegig
Junior Member
Anyone tried turning a Dunerunner 4WD into a 2WD by removing a shaft ?
If so what is the better way to do it ?
i would think removing not only the front drive shaft but also replace the front cvd's (if you have them) w/rear drive cups for axles or just remove the cvd from the drive cup/axle. that way the gears in the diff do not turn w/the wheels.
I tried in 2wd last year and I had new pins in my 3 remaining dogbones to keep it 2wd and i chewed the pins more then 90% in 2 tanks so 4wd for the dunney
RCDAD said:
I'd just run it with the front wheels off. :D JK
Better yet I will try skis up front on grass with kold cutters on some hostiles :rolleyes: maybe try hitting the lake to to keep the pins well lubricated with rust haha j.k guys
