changing solenoids
philztoy
I have noticed that there is no direct swap for solenoids in the MTand it seems someone mentioned that new ones will fit if you use the redcat aluminum mounts. I have new solenoids but am a little concerned about changing them if I don't have the proper mount. I am not sure which mount that is and I have been looking.
Is this the part, the 710008 Servo Set ?
Any help would be appreciated?
Phil
Use the stock lower holes and leave the little screw section that sticks out and then Cut the top nubs off and drill new holes. Super easy I have done it 3 times
