Charge mod
ika
I made little modification on transmiter and radio box.
I opened transmiter , made wireing diagram modification and able to charge transmiter by charging port.
I made that charging port is active onle when power is off. So you can't charge when transmiter is on.
Same is done on radio box. View attachment 7548View attachment 7549
As you see on pics , i have installed charging connection and no need to remove battery to charge.
Charging port on radio box only charges when receiver is off.
nice, yeah most people get tired of removing their battery.
I have a Y cable with a female Port hanging out where the servo wires go in, used this pre-switch so with the switch off you can charge your battery w/o powering up the receiver/servos.
Good thing about have a female lead out is you can plug in another battery zip tied somewhere, to run (2) in Parallel, great for those long endurance races!
