tizdaz
- Sunny Northwest!
Hi guys
ok just picked up a new 5000mah 6v pack..
5x 1.2v C-Cells
Capacity : 5000mAh
Weight : 370g
Measured at 5000mA (0.2C) discharge.
Max Discharge Current : 30,000mA (30 Amps)
Max Charge Current : 5000mA
Fitting : Tamiya & Futaba
Size : 111mm x 46mm x 24mm
In the past ive always done a quick charge as my old charger is kinda basic as i jus connected the batter to it & pressed the start button then wait till it beeps & its done! but this charger is old & 5000mah werent around back then when this was released so im guessing its not ideal for charging 5000mah? ... http://www.ironfoot.co.uk/shop/index.php?act=viewProd&productId=441
anyway picked up a new charger a while back & not used it yet, as its a little confusing as i aint too great with the math behind charging batteries so hopefully you guys can help!
new charger i have now is this one..
http://www.v-eastonline.com/products/ULTRAMAT-6-.html & batterys i wanna charge is C-Cells (5x 1.2v cells) 6v 5000mah pack & same again but 4600mah which is my old battery but still working fine.
any info/help on this much appreciated as i don't wanna damage my new battery ive just bought & i wanna kinda understand what these mean on my charger:
Charge Current, toggle switch with options of 0.2 / 0.5 & 1.0
Delta Peak mv/cell, toggle switch with options of 5, 10 & 20
thats just dbl dutch to meh! ?
ta
5x 1.2v C-Cells
Capacity : 5000mAh
Weight : 370g
ta
