Chassis Ground clearance?
FastEddy
LSF Vendor!
LSF vendor
Sonoma County CA
Whats the chassis ground clearance in the MT?
If you lift the truck just until the wheels come off the ground, what id the measurement from the ground to the bottom of the chassis?
What tires are you running with your measurement?
Thanks,
-Ed
I measured as asked and here is what I got:
3 5/8 in the rear
2 3/4 in the front to where the bend in the chassis is (lowest part)
I am running the stock FG Monster tires (actually it is a Monster Beetle Pro, but should be the same)
Hope that helps....what are you up too Eddy???
