chassis
kydo32
is the chassis on the mt slightly bent or straight in the front end ? mine seems bent upwards . Do they make a stronger chassis? and do they make a water proofed servo I can use for throttle/brake?
I don't have a MT but if its anything like the x series the chassis will have about 9°upwards bend in the front....rear will be flat. If you look on a xb you can see the stamp for the bend just below the front pinion cup on the housing... I'm sure its the same concept with the mt.
Yes, it is bent like most RC cars.
No one makes a stringer one, but if you add shock tower to chassis braces, it will help a lot with flex.
