benckie
here is my cheap 2 channel 1 to 8 cell charger, its a hotbodies gt exscape
ive been using this one for over 1 year now, and i have had this type of charger befor on my nitros it was great for charging two stick packs at a time and great on my savage i could charge the rx battery my radio and a couple of stick packs for the rotor start so i could bash all day.
its a 2 channel so i can charge two rc cars at once, and i can charge my l/s car and radio at the same time, i use it for my camera batteries and batters around the house, it will charge one to 8 cells, i take it on family trips to charger camera batteries and so on.
its a simple charger will not do lipo,s it don't have a fancey display, but has simple reds lights to let you know when its charging and when its finshed charging and it auto cuts off when the batteris are ready, it also has its own cooling fan built in and each channel you can slid a switch for 1, 2, 4 amp charge, each channel is fused seperate.
its 12 volt dc, so i can use it out and about and charge things from my cigeret lighter in the car or it comes with direct battery conector, i have modifed a 12 volt 9 amp 240 volt power supply so i can easly charge things from 240 volt at home and in the shed, i have also modded a multy charging lead to make like easyer when im charging 8 aa batteries for my radios and cameras, but i had just added a futaba charging jack and removed my old specktum charging jack, so i don't realy have to use the 8 cell battery holders for charging.
here is a picture of the charger, its a hot boddies, its recomend by hpi for most of there cars and it comes with the electric savage that runs twin batteries, and comes with two leads for chargine stick packs,on one channel ive added the multy charging lead to it and the secon channel ive has the standard charging lead for what you find on most large scale cars or stic packs.
here is the 12 volt 9 amp 240 volt ac power supply i simply modded and add a 3 cigerlighter and 1 usb charger adapter glued it to the top, i just had to make a couple of quick mods inside and do some soldering to the power supply, ive been using this power supplier for over 12 months i won it cheap of ebay it was from hong kong.
here is the battery direct connector and a spektrum 8 cell batter holder i use to chage multible aa,s for radios, and my kids toys
i use one of these an old 4 cell aa battery hold like what you would find in a rtr nitro to charge my 4 good camera batteries, i knew it had to be good for some thing, i aslo use it for test things
ive used a few expencive flash chargers with lcd screans, but this is the only charge ive kept its simple works well and being able to charge two seperate things at one time is a real bonus for me.
