miniripper
Seen this posted on a few forums!
This is the very first production largescale engine to hit the market.
It will be sold as a long block and flywheel it is compatable with all existing Zenoha, CY and aftermarket ignitions, fan covers, pullstarts and the like.
3 different displacements available on launch 23,26 and 28.5cc
It is read case induction! Compatable with all existing walbro carbs.
Closed deck ports.
Nikasealed cylinder and piston.
No gaskets used with head, cylinder and crank cases all O'rings made for the job.
No longer a need to worry about Squish it's all done for you with Italian flair.
Much bigger crank case journals. This allows the use of much bigger crank bearings. No more failures!
Low drag BZM crank seals.
Compatible with all current clutchs and clutch cases.
This engine is the evolution that we have all been waiting for finally a bespoke petrol engine that can't be called a weed wacker motor! It's been made by the best to give you the best!
Official product launch will be at the Nurenburg international toy fair in Febuary next year.
Watch this space www.BZM-Micro.com
Closed deck ports.
