smurfer69
- Weston super mare
hi guys anyone know what brakes these are bought these about
4 yrs ago, just pulled from dusty shelf to have another go at em
they are weird they got a membrane on master cylinder between
cylinder and metal plate screwed on with 4 screws,
I guess for fluid pressure to work piston ??
also where the piston goes through brass fitting
when it was screwed tight the piston would hardly move
so matter how good the servo this b---h aint gonna work properly
if at all ,so what I did was drill the holes bigger by a 1/16
and now run smooth as silk.
I pretty much guarantee you cannot a replacement membrane
so again my mod was cut a piece of 1mm rubber membrane
to shape force screws through presto sorted
I have put a thread on here regarding GTB front considerably better looking
than these Chinese knockoffs, but they hardly need any movement now piston is sorted
and lock up like Bugatti
