CyberVet65
OK we got a ton of thread about starting and playing and tuning.
Whet we need now is a check list of what you do when the day is done. Other than fixing the broken stuff.
Drain fuel?
Hose it down the if you have a compressor blow it dry.
Where not to use the air?
Wipe it down with anything?
Put any oil into the engine to keep it lubed?
Store it where?
Hang it up or let it set on the tires?
Remove the tires to store?
Some of this is common sense but it depends on how long it is between runs. Some folks like me will run a lot. I am retired and I have tht time. Some folks will run once in a while and some folks will only run on the weekends.
Storage can be an issue.
So let's do a list.
Drain fuel?
Store it where?
So let's do a list.
