cleaning the engine and carb
Killer Bee - check their site and watch their videos - very clear.
If you're buying from MMR, after the vids, give them a call - they'll always help you out.
Check the system before firing up, once all is installed. If you're 4WD it's a little more complicated, else if 2WD, take it outside, raise the driven wheels, and go through a simple test.
If you've a 3channel one, check with the toggle on your Rx, else if a 2-channel, just switch it off. The engine should cut out immediately.
Option4? - you mean with the light - nice touch.
Did you get V1, V2, V2S. V2 - 2 channel. V2S - 2 channel Spektrum.
v1 with the light and busser
Mike a little help here.I don't mean to be offensive but your spelling is pretty hard to comprehend . Load Google Chrome,it will give you the spell check option.
J.
Cheers buddy, I'm using KillerBee v2s..dedicated to Spekky's. But would like to know if the one above, cheaper option, would work with Spekky's =)
I'd put it thisway;
If you're an electrician and have full confidence in what you're doing, then go ahead, if not DON'T DO IT!!
Not one Large Scale weighs less than 12kg and will top 35-40mph with ease - do you want to get it wrong? :w00t::w00t::w00t: :mad::mad::mad:
